4300 HST dropping bucket problem
Gary Barner
04-13-2005 10:12:10
I have a JD 4300 that I purchased new in December, 2001. It only has 250 hours on it and has been serviced regularly. A couple of months ago, I noticed that whenever I started to raise the bucket, it would drop several inches prior to raising. It has been at the local dealer for about a month and they cannot find the cause of the problem. They have replaced o-rings in the controls and even replaced the whole control box.
Has anyone else experienced similar problems?
Thanks, Gary
Heat Houser
04-13-2005 19:01:02
 Re: 4300 HST dropping bucket problem in reply to Gary Barner, 04-13-2005 10:12:10
"Replaced the whole control box", do you mean the loader control valve? It sounds like you have a load check stuck open/damaged but if the whole valve was replaced, the checks should have been part of the assy.
Gary Barner
04-13-2005 19:57:19
 Re: 4300 HST dropping bucket problem in reply to Heat Houser, 04-13-2005 19:01:02
I will double check with the John Deere dealer tomorrow, but I believe he has replaced the entire control valve assembly. Thanks for your response.
