Early styled B power shaft
Jason Z in MO
04-13-2005 08:29:17
I am working on a JD B SN 81291. Flat back, no hydraulics.
This weekend I was able to get the main case stripped, cleaned and primered. I am moved around the bend and now re-installing parts! MAN, I AM TIRED OF CLEANING!
I hit my first question... The service manual says to adjust the backlash on the bevel gear and bevel pinion to .006 and .010". Either use a dial indicator or a feeler gauge.
If I use a feeler gauge do I slip it between the meshed gear tooth faces?
I have a dial indicator but don't have any mounting hardware.
Ken Tabor
04-14-2005 05:32:10
 Re: Early styled B power shaft in reply to Jason Z in MO, 04-13-2005 08:29:17
I am apparently at the same stage you are at on my project. I don't have much of a manual and didn't see anything about tolerances at the two gears. Are these shimmed? How is the tolerance adjusted. I did notice that there seems to be a bit too much play on my tractor but other than taking it the cross shaft out and shimming the the other gear don't see how an adjustment can be made
Ken
Jason Z in MO
04-14-2005 07:54:20
 Re: Early styled B power shaft in reply to Ken Tabor, 04-14-2005 05:32:10
Ken,
You are right. The shaft that runs cross-wise in the case is shimed under the right hand cover.
You might also have too much wear on the bevel gear thrust washer. Mine is in good shape.
Ken Tabor
04-14-2005 18:12:21
 Re: Early styled B power shaft in reply to Jason Z in MO, 04-14-2005 07:54:20
I figured out the gasket shim after going back out to the garage. Grizzly.com has a dial gage and magnetic base for something like 25 dollars. I am hoping to get the remainder of the transmission assembled this weekend
Ken
