1967 John Deere 4020
AutobahnTrader.com
04-12-2005 19:44:58
1. How much HP did the 1967 John Deere 4020 diesel have? 2. How much would one be worth in a good condition?
The one I'm looking at has a 580 Allied loader, 3 PTH, 5 Speed Syro, Cosy Cab. I have 10 acres most treed so I'd like to use this tractor to move dirt, push trees over (~10" diameter) and any other general work... Can this tractor handle that?
txgrn
04-13-2005 23:14:36
 Re: 1967 John Deere 4020 in reply to AutobahnTrader.com, 04-12-2005 19:44:58
V Getis Enin.
2 things.
1. I used my loader to dig with and would up bending the shafts on my bucket cylinders. I would push the bucket all the way down, then push it into the ground till the front wheels were off the ground, and then back up. Don't do it.
2. I need a good source for after market or used parts for a 2120 which I think was built in Germany. Right now need steering parts. Help would be appreciated.
Thanks,
Mark
AutobahnTrader.com
04-16-2005 14:17:03
 Re: 1967 John Deere 4020 in reply to txgrn, 04-13-2005 23:14:36
Thanks for all replies.
Well the tractor sold for a bit more then I wanted to pay ($7500). I'm thinking an old construction loader/backhoe will serve me better.
Jim in AK
04-13-2005 00:54:51
My 4010D with a syncro has a dozer blade that dose an assume job on the trees here. I do not run in to them I push them over. If they resist being pushed over. I use a ripper tooth that I bolt to one side of the blade to cut the roots first. I can tell you that I could have done better for less by renting a dozer. By the way My syncro has 8 forward and 3, (three), reverse. I also use mine to skid saw timber and to place the saw timber in the mill. My 4010 is not much for looks but is a hell of a work horse. And plows my snow in the winter.
Spring got here this morning about 10 am. The swans returned to the still froze over pond. It sure was a welcome site.
Jim
msb
04-12-2005 22:08:59
67 4020 had an advertized horsepower rating of 94 pto hp. but most all that I checked of about a 100 came fron the factory at about 105 hp I have taken out some pretty big trees with the old 48 Deere loader I used to have by first digging around the roots as much as I could and then raising the loader as high as practical to get as much leverage on the tree as possible.
I once hired a man with a little D4 Cat and he did exactly the same except he had a straight blade so he built a dirt ramp up to this huge tree with dirt and pushed the tree right out.I never would have believed it if I hadn't seen it myself.
klj
04-12-2005 21:21:32
4020 0n 10a. would be handy as a pocket in a shirt. but won"t last long doing dozer work.
Gerald J.
04-12-2005 20:34:06
 Re: 1967 P.S. in reply to AutobahnTrader.com, 04-12-2005 19:44:58
That cab isn't a ROPS either, just a tin coffin, that is noisy, and dirty. Won't hold up trees falling on it.
Gerald J.
Gerald J.
04-12-2005 20:31:49
'67 4020D about 88 hp. They didn't make a 5 speed. It was 8 speeds forward two reverse in the syncro range.
As for pushing trees, it won't. I tried that last winter with mine, I was able to break off 5 or 6" limbs, but hitting stuff bigger broke the bucket on the loader.
Loader buckets tend to be hard to control for digging. First the won't dig, so you tilt the bucket a bit more and it finds some slop in the cylinder and pivots and digs to China. I made a shorter bucket for mine but a back hoe is a whole lot handier for digging other than in dirt piles.
'67 SR 4020D go for 6 to 10K.
Gerald J.
