1950 A pistons
Eli
04-12-2005 18:57:17
Just bought an all fuel A. It needs a new manifold but I"m not sure if it has the high or low compression pistons. How can I tell? If low compression I would like to use the allfuel manifold. Any advice appreciated. Thanks Eli
Mike Aylward
04-12-2005 20:06:17
 Re: 1950 A pistons in reply to Eli, 04-12-2005 18:57:17
Eli, are you sure your A is an all-fuel? If it has a heat shield under the tank it might be one of the ones that have the second tank but were still factory gas tractors. This was done as a stop gap measure before the tanks were enlarged later. A second tank on these tractors does not necessarily make it an all-fuel. But you probably know what you have. The easiest way to know what pistons you have is to remove the crankcase cover and look at the part number in the inside skirt area of the pistons. This will let you know the type and size of piston you have. Hope this helps. Mike
Eli
04-13-2005 18:28:44
 Re: 1950 A pistons in reply to Mike Aylward, 04-12-2005 20:06:17
Thanks Mike, That helped alot. I do have the heat shield, and the manifold it came with is a gas. I,ll double check the piston part number.Thanks again, Eli
