JD 5020 breaks
stan
02-20-2004 16:15:49
I have my final drive off, and see the breaks appear to have been draging. I dont know if this happened recently, or in the past.The break disc was warped, and was blue in color. I am going to replace this. I would like to know if there is a problem to make the breaks drag?
david val
02-21-2004 00:09:53
 Re: JD 5020 breaks in reply to stan, 02-20-2004 16:15:49
brake drag can be the result of a bad brake valve. a simple check: disconnect the brake lines at the brake valve and start the engine. if there is oil flowing out of the valve fitting(s), then the brake valve needs repair.
david
stan
02-21-2004 08:37:57
 Re: Re: JD 5020 breaks in reply to david val, 02-21-2004 00:09:53
Are you talking about the valve under the break peddel? This sounds like a good test thanks. Stan
