Electrolisis on GP
Lynda
04-12-2005 18:00:38
Just wondering if we are doing this right. We got a 100 gallon rubber tub, filled half with water, and we used 2 cups of Lye. We hooked the ground to the part and the positive to a scrap piece of steel. Did we forget anything? How long should it take to clean the part?
Thanks Lynda
Lynda
04-13-2005 15:03:44
 Re: Electrolisis on GP in reply to Lynda, 04-12-2005 18:00:38
Thanks for your help
lynda
04-13-2005 06:53:58
we are using Red Devil drain opener lye at says its 100% lye will this stuff work
36BinMN
04-13-2005 07:11:07
 Re: Electrolisis on GP in reply to lynda, 04-13-2005 06:53:58
Yes Lynda, That should work, I think that's what the guys are using also. Good Luck
Jason Z in MO
04-13-2005 07:02:26
Lynda,
I also use Red Devil, works fine. As Bman points out, electricity flows through the path of least resistance. So the area closest to your sacrificial anode will get the cleanest. As you clean you can move it around to get the other areas as well. I would generally leave my parts in over night but I have left them in for several days just because I didn't have time to get them out and cleaned.
On some stuff you might find it helpful to pull them out wire brush them off and cook them for a second time.
Also I found on smooth parts (sheet metal and such) instead of using a wire brush to knock the crude off a scotch bright pad does a great job.
36BinMN
04-12-2005 22:03:06
Hi, Well first off the time it takes to clean a part is Dependant how dirty it is, # of coats of paint and how many amps your are conducting.
I personally don't use lye (just because I can't find it here, I use washing soda) My mix is about 1 Tbl. spoon to a gallon of water.
I have tried a lot of different set ups and find you should have at least 1/2 as much surface area of electrode as you do the part being cleaned, and the part will only get really clean if it is in line with the electrode If the electrode is one one side of a piece of sheet metal only the side next to it will be cleaned!!!
For best results your charger should be putting out between 4 and 8 amps. This depends on your charger though too. "most" chargers will put out 80% of there capacity continuously and not trip the breaker or get warm and shut off
For example the charger I use is 10,30 and 200 amps it will put out 20 amps continues hooked to the tank and that is what I run it at. You can adjust how much your charger draws by adding more or less lye and or washing soda (more lye-soda more draw on the charger) this also affected by how close your electrode is to your part to be cleaned.
You just need to tinker around with it tiil you find what works best for your tank and charger. Never let the two part touch (lotta sparks and a broken charger will resust)
Here is a link to the site I learned all of this from, you can mail him and he is most happy to help you out with any more question's or post back and I will help if I can. Just click on restoration tips
