JD 430 power steering pump. Need GPM, and PSI.
cdm
04-12-2005 16:57:13
MY JD 430 power steering pump is broken beyond repair. I am going to use a Vickers pump in replace of my broken JD pump. I am trying to match the new pump up as close as possible to factory spec.. Can anyone tell me what the correct GPM, and PSI was on the original pumps?
Thanks, in advance
Henry J
04-12-2005 17:11:07
 Re: JD 430 power steering pump. Need GPM, and PSI. in reply to cdm, 04-12-2005 16:57:13
cdm
Getting info on those pumps can be a challenge since the 420/430 repair manuals are kinda void.
Based on JR Hobbs suggestion, I got the manual on the 440 when I was groping with my pump. It had good information and details in it. Also I ran down a service manual of the ps pump on the jd 420 and 440 series tractors. Anyway, when comparing pictures it seems to me that all the info I have is for the pump for sn 131818-158074 (that is the one with the large round cap on top of the pump reservoir.
Both the books say that the pump has a combination pressure relief valve and flow control valve. The relief valve is set at approx 1000 psi and the flow control portion of that valve recirculates oil within the pump as required to regulate the output volume to the steering valve at approx 2-1/4 gallons per minute.
I venture to say that the newer style pump with the tall fill neck and small radiator type cap is probably the same.
cdm
04-13-2005 03:17:07
 Re: JD 430 power steering pump. Need GPM, and PSI. in reply to Henry J, 04-12-2005 17:11:07
thank you very much. I will use those numbers, and will be happy to share the part numbers and results. would like to get my hands on copies of those manuals.
thanks again
