Cold temperature diesel starting
Charlie1520
04-12-2005 11:37:54
I've recently purchased my first diesel tractor (JD1530) and I am having real problems getting it started if the temperature gets below something like 40 degrees. It does have a water heater that after I plug it in for about 30 to 60 minutes will start okay then. I am just wondering at what temperature is it normal for diesels to need starting aids? Thanks.
mitchp
04-13-2005 12:56:29
 Re: Cold temperature diesel starting in reply to Charlie1520, 04-12-2005 11:37:54
does this tractor have a air intake heater? should be on the right hand side of the lower dash in front of the right gear shift, it'll be a back button you can hold in till you here a "poof" and that really helps. if you have a silver thing sticking out, thats for a can of starting fluid. my 2120 has a intake heater and really works well in cold weather
buickanddeere
04-12-2005 13:15:41
A 30 to 33 year old tractor with how many hours on a set of original injectors & pump. With how much compression pressure which contributes to heat. Lost due to piston/ring/sleeve blowby and leaking valves. Compression is lower yet and starting poorer if some cheapskate ground the seats and valves thus sinking them deeper. As previously stated cranking rpms maybe slow due to several reasons. Cranking rpm also contributes to the amount of heat in the combustion chamber to ignite the fuel oil. What is the voltage measured between the starter's cast body. And the big brass post going into the starter motor. Not the cable to the solenoid. The 20 and 30 series were not as good a cold weather starting tractor as a 40 through 55 series. How thick is the crankcase oil? Is the hydraulic pump destroking or is the starter pumping up 2250 psi hydraulic pressure as well? Any difference when starting with the clutch pedal fully depressed? Should always start that way anyways. 40F and starting with � a dozen turns isn�t too shabby with any non glowplug diesel. What is the cetane value of the fuel?
Mike M
04-12-2005 12:33:47
That sounds a little warm to have starting problems weather related ? If your engine is good I would check into slow cranking speed.Causes could be weak batteries,old cables,even had a 2640 with a weak armature in the starter act like yours.That one took about 3 starter shops to find it.
