jd 3020 reverse gear
jpoole
04-12-2005 10:58:35
I used the tractor all day sunday . Suddenly when I put it in reverse the gears just grind . The same is happening on both reverses . Can this be some kind of linkage adjustment . Or is it more complecated
WTW
04-12-2005 12:41:41
 Re: jd 3020 reverse gear in reply to jpoole, 04-12-2005 10:58:35
Shifting mechanism in dash is worn and loose causing operator to over shift and miss-position shift cams in transmission. If miss shift can be corrected by repositioning lever in dash and tractor does not jump out of gear after doing this repair to the shift quadrant in dash may correct your problem. If it still continues to jump out, damage from wear and over shifting has worn out your reverse synchronizer. If adjustment was the reason for your failure your forward speeds would also be out of adjustment as one control rod / adjustment affects both. To repair synchronizer tractor will have to be split between clutch housing and transmission, rockshaft assembly removed and top shaft removed and rebuilt. Very common wear point on older tractor especially one used for shuttle type work with allot of hours. DW
thurlow
04-12-2005 12:38:39
Are you "overshifting" it, i.e. jamming it into gear; try just laying it (lever) gently into the selected gear/gate; see if that helps.
