AR Carb Problem??
MB in NE
04-11-2005 23:32:22
I finally got my 49 AR started the other day but I had to have the choke almost completely closed. Now, I don"t have a inlet pipe, (the pipe from the air cleaner to the carb). Could this be part of the problem,? or does the carb need to be over hauled? It runs fine at all speeds this way and doesn"t smoke like its getting to much gas. Like I said the choke is just barly open, maybe about the size of a pencil lead could get through. Thanks for any help.
Duane Larson
04-12-2005 06:20:07
 Re: AR Carb Problem?? in reply to MB in NE, 04-11-2005 23:32:22
MB,
I assume your tractor is running at idle, not under load. I doubt the lack of the air intake system would cause your problem. It sounds like a classic case of a plugged idle circuit, so fuel must come through the load circuit (ie, from the main nozzle). It probably does not idle smoothly and lopes. As the engine slows down the throttle plate opens and vacuum at the nozzle increases, drawing fuel from the nozzle in a gulp. The engine then speeds up and as the fuel is burned it slows down and the process repeats. If the tractor has set for a long time with fuel in the carb, plugged idle circuits and plugged acceleration holes in the fuel nozzle are quite common.
RonMC
04-12-2005 15:26:49
 Re: AR Carb Problem?? in reply to Duane Larson, 04-12-2005 06:20:07
Duane, would you happen to have an exploded view as to the exact or close(?) location of the idle passage ? I know when I did my M carb, it was a little hard to see and had crusted over. I'm about to pull the carb off my own AR for the serious overhaul and any info is of course very useful. It has been hard starting lately which sort of tells me that the idle circuit is not good. I overhauled the M and MC and they both fire up nearly on the first compression and it would be nice if the AR would do the same thing ! Thanks for any help, Ron
Duane Larson
04-13-2005 08:35:27
 Re: AR Carb Problem?? in reply to RonMC, 04-12-2005 15:26:49
RonMC,
Check your email.
