4640 broken wheel wedge
Mark Lange
04-11-2005 21:58:08
I have a 4640 and was attempting to loosen the wheel wedge so I could move the wheels and it broke in half. The part that the bolts screw into broke loose from the part that wedges in the casting. I have no idea how to get the rest of the wedge out of the cast center. I made a tool out of 4" pipe and cut half of it of on the end to contact the wedge. I then beat on it with a sledgehammer repeatedly, but the wedge just won't budge. Does anyone have any experience with this and ideas I can try? Any help would be very much appreciated.
Mark Lange
WTW
04-12-2005 06:50:29
 Re: 4640 broken wheel wedge in reply to Mark Lange, 04-11-2005 21:58:08
Mark, Here is a way I have done it with the circumstances that you have (before and after the wedge or bolts were broken). First, loosen the three 3/4" bolts on the stationary wedge on the inside of the wheel just enough to relieve the lock washers under the heads of them. Second, jack up the tractor far enough to suspend the wheel that you are moving off the ground. Third, block off the end of the final drive axle housing edge with heavy iron bars or plates (must be iron not wood). Block right up as close as you can get to the heads of the three inner bolts (will require different amounts of block height depending on how far the wheels are out on the axle). Fourth, continue to back out the three inner wedge bolts against the iron blocks with an open end wrench. Use the best wrench that you have and tighten all three bolts until you either move the wheel off the wedges or you can not turn them anymore. In the event that the wheel does not move and you have the three inner bolts as tight as you can get them, Strike the end of the axle with the heaviest mall you can swing. after two or three licks tighten the inner bolts some more. This should eventually move the wheel off the axle wedges. What you are doing instead of forcing one stuck (now broken) wedge out from between the wheel and axle with two bolts, instead you are forcing the wheel off both wedges with three bolts. After you get the wheel loose and you are ready to reposition it, be sure to tighten the inner stationary wedge in the wheel first. A little time will be spent doing it this way, but it usually works and sometimes you have no other choice. Good Luck, DW
Mark Lange
04-12-2005 07:27:19
 Re: 4640 broken wheel wedge in reply to WTW, 04-12-2005 06:50:29
I should have mentioned I have the 1500lbs. inside wheel weights. This makes getting at the inside wedge bolts impossible. Is there anything else I can try? I'm in big trouble with this and I need the tractor right away. Thanks for the help.
Mark
WTW
04-12-2005 09:15:11
 Re: 4640 broken wheel wedge in reply to Mark Lange, 04-12-2005 07:27:19
Mark, Now you are putting a twist on it! I still would figure out a way to go in through weight hole with either a swivel (if wheel is out far enough) or a torque adapter type wrench on the end of a 3/4" drive extension and loosen the three inner wedge bolts. You may have to go as far as loosening the inner weight to let it down to make room for tools and gain better access to theses inner bolts. I would always keep at least one longer bolt in one of the weight mounting holes to control and help man handle the weight. Be careful if you have to do this as it would be a real live smasher if it was to slip! Once I got the inner bolts loose I would then rig a (big) hydraulic jack / porta power (30 ton plus) to the end of the axle with a (very) heavy cross iron block with each end bolted to cast wheel through two of the weight bolt holes. You will have to use a cross iron and bolts as a chain will just stretch. Tighten hydraulic jack up to where you think it can't take it any more and if it don't come loose strike the cross iron over axle center and hope the hell it comes loose. I really do not think you will ever loosen the wheel on axle without loosening the inner stationary wedge bolts as this method will not work either without inner bolts loose. So what ever it takes plan on getting the inner bolts loose. I have seen tractors with the wedge shoulder broke off it like yours that were used to plow in the furrow for years that never did come loose. Another option that might work for you instead of the cross iron and bolts is place two jacks across from each other around axle housing against inner weight and final drive mounting bolt heads and push wheel from wedges this way. If push comes to shove (no pun intended) use both methods at once. If I was you I would start this process by removing tire and rim from cast wheel to gain all the room you can get as you will need it. I have also seen people loosen the inner wedge bolts and drive the tractor around working the brakes sometimes they loosen and some times they don't. On several of them that I did see break loose by driving them it also cost the tractor owner a new fender on the cab when wheel came loose, so I do not recommend driving the tractor. One thing for sure this job is not going to be fun. Be Careful!! DW
Tx Jim
04-12-2005 04:09:44
Mark,it's been a long time since I've looked at a 4640 but it should have 3 bolts on inside of wheel that holds one of the wedges.I think you would have to take this wedge out first.Jim
