What should I offer for a 1934 A?
Big_Roy
04-11-2005 21:19:13
There is a unstyled 1934 A sitting in my neighbors pasture. It's not stuck, no visable cracks in the block, head, covers, or main case, and visually looks like it's in good shape. If I remember right it's on cut offs on the rear and round spoked fronts (rubber).
I don't have a picture of it right now but what would ya'll say something like that would be worth?
Big_Roy
04-12-2005 19:48:20
 Re: What should I offer for a 1934 A? in reply to Big_Roy, 04-11-2005 21:19:13
Well I talked to the owner this evening. He certainly know what he has because he wants $2500 cash. (Ouch!) I took some pics and will attach them below. Just by compairing with the information in the book "A Specialized Look Into The Unstyled Model A" by Wes Malcom the mag is obviously not correct (Wico C), the radiator cap is a later model replacement, and it's on rubber rims instead of steel. There is also a weld on the lower left of the bottom radiator tank(in pic). Everything else appears to be all orignal 1934.
JDBert
04-13-2005 09:11:24
 Re: What should I offer for a 1934 A? in reply to Big_Roy, 04-12-2005 19:48:20
If I'm seeing it correctly in JPEG #2 it looks like the upper water piper has been frozen and broke at some point in its life, I would be checking the block and head as well for freeze damage. Other then that I would say hes alittle high. This is a rare "A" though with all the proper goodies. Are the front spokes cutoffs or actual round spokes?
Big_Roy
04-13-2005 11:55:48
 Re: What should I offer for a 1934 A? in reply to JDBert, 04-13-2005 09:11:24
No that's just the way the pic looks after I reduced it to post. It is solid and not cracked, just rusty.
Yes those are actual round spokes not cutoffs.
Deeredale
04-12-2005 19:55:21
Looks like all the hard to find parts are there. It really does not sound too bad. That is a fairly rare tractor. I bet if you don't want it there will be several takers on this board.
Big_Roy
04-12-2005 20:09:07
 Re: What should I offer for a 1934 A? in reply to Deeredale, 04-12-2005 19:55:21
I've been after it for about 3 years now. So barring the unexpected I'm hoping to have a home for it. But if something occurs that I can't....well I don't want to think about that! ;-)
Thanks,
Roy
Nick K
04-12-2005 19:22:52
If it is a true 34, with the open fan shaft, it is worth a lot. A restored one will bring over 10,000
old
04-12-2005 09:36:54
Any where from $100-1000 depending on tires sheet metal etc.
Deeredale
04-12-2005 19:49:07
 Re: What should I offer for a 1934 A? in reply to old, 04-12-2005 09:36:54
Old, Where are you from? I want to move there. It seems like you find allot of very cheap tractors in your area. A 1934 A with correct parts will bring 3000.00 if it is a boat anchor & up to 10,000.00 if restored.
Big_Roy
04-12-2005 19:55:00
 Re: What should I offer for a 1934 A? in reply to Deeredale, 04-12-2005 19:49:07
If that's the case I'd better jump all over this one. Especially since I can pratically push it to my place. ;)
