Clooney I need your help!
Debbie Banko
04-11-2005 19:28:07
We have a JD SX75 Riding Mower. The engine is behind the seat (if that info helps). It would only move in gears 4-7. The gears 1-3 and reverse would not move the mower.
We replaced both primary and secondary belts. Took it for a spin around the yard and it worked fine. Turned it off for a few minutes. Went back and cranked it up and was back to the gears 4-7 only working. Then we loosened the bolt that I guess goes to the spring and had to do that twice. THAT WORKED! Later on we cranked her back up and when it was put in any gear the engine bogged down and stopped!! We are at a loss. Do you know what the problem could be now?
Thanks for your time and knowledge
Debbie
C R
04-12-2005 10:27:00
 Re: Clooney I need your help! in reply to Debbie Banko, 04-11-2005 19:28:07
Debbie, I read your earlier post also and have no knowledge of how to help you except to say you may have to take it into a repair shop. If no one else has answered than no one has an answer.
I believe Clooney is out of the country right now, no idea when he will return.
Sorry I can't help.
The best of luck to you.
Debbie Banko
04-12-2005 23:47:41
 Re: Clooney I need your help! in reply to C R, 04-12-2005 10:27:00
Thank you for your time. You people are great!
Debbie
