1950 JD B Miscellaneous Questions
elcajonfarms
04-11-2005 15:47:51
I have a few questions that due to passage of time and changing terminology do not appear answered in the vintage operator's manual I have for this tractor:
1. What kind of unleaded gasoline and/or fuel additives would you use in a 1950 B (this is NOT an all-fuel model)?
2. What is the current correct Champion spark plug number for this tractor?
3. What modern weight/viscosity/grade for (1) engine oil, (2) gearbox oil, (3) hydraulic/powertrol fluid, (4) air cleaner cup oil?
Any suggestions would be appreciated.
Mike M
04-12-2005 04:06:05
 Re: 1950 JD B Miscellaneous Questions in reply to elcajonfarms, 04-11-2005 15:47:51
The cheapest gas you can find. No Champions (heard too much bad about them)use Autolite 388 I use whatever engine oil I have usually keep 15w40 around some of my stuff gets run in the winter. 30w maybe better in summer. Any new clean oil is better than dirty or none. Trans. I usually put in what I can find 80-90 or 85-140 Hyd. I use John Deere Hy-Gard as I have it around for the newer tractors. If you don't have any other tractors buy the cheapest hyd. oil you can find or just try engine oil in it. Those old tractors aren't too fussy. Keepin it changed to keep the water and crap out is more important than what brand or weight is used. The only damage I have witnessed was from low or no oil,gas in oil,water in oil and OPERATOR ABUSE. I don't think that brand X,y,or z matters or the weight of it.
Duane Larson
04-11-2005 21:11:40
elcajonfarms,
If your B was built before 5/50 it came with Champion 8Com or Edison Splitdorf Z142 plugs. After 5/50 it came with AC88L-Com plugs. Champion 8Com translates to D16, ES plugs are no longer available, and the AC88L-Com plugs translate to C88L.
As noted by others, the heat range of plugs which came in new equipment was mid-range - designed to meet requirements of heavy and light work. I agree that for most use of antique tractors these days, the hottest available plug should be used. In fact, the reason for changing from Champion 8Com to AC88L-Com plugs was the 8Com was not hot enough, and was the hottest Champion available at the time. It ended up being replaced by the Champion 10Com64 plug, developed to compete with the AC88L-Com.
jdman(MO)
04-11-2005 18:14:45
1. Use 87 octane gas
2. These tractors came out with Champion D-16, but for limited use I suggest D-23 or other plug equals. They all seem to foul sometimes.
3. 30W for the engine, Powertrol, and Filter cup. In winter (cold) 10W.
4. 85-90 in the transmission.
RayP(MI)
04-11-2005 18:39:15
 Re: 1950 JD B Miscellaneous Questions in reply to jdman(MO), 04-11-2005 18:14:45
Use 87 octane nolead in my '49 B. Seeing no problems. We even use her to run a baler.
Dave in Ohio
04-11-2005 17:47:53
Since there is no lead in todays gasoline I use the highest octane fuel that I can buy. (high test) on all my old tractors. As for spark plugs I stick with AC or Autolite.
Bob
04-11-2005 19:45:56
 Re: 1950 JD B Miscellaneous Questions in reply to Dave in Ohio, 04-11-2005 17:47:53
Why in the world do you think an old low-compresion tractor needs high octane gas????? ????
Dave in Ohio
04-12-2005 05:21:51
 Re: 1950 JD B Miscellaneous Questions in reply to Bob, 04-11-2005 19:45:56
I believe my tractors perform better and foul plugs less on high octane fuel. I don't care what anyone else burns that my openion and my money.
Bob
04-12-2005 09:26:39
 Re: 1950 JD B Miscellaneous Questions in reply to Dave in Ohio, 04-12-2005 05:21:51
Interesting observation. It would be interesting to see a scientific evaluation of this, as there are people with strong opinions both ways.
I wonder what the truth really is???
Arthur Driesse
04-11-2005 17:20:41
I think regular gas would be good, as for additives, if you use them ( they do help ) use a petroleum based product not a teflon or other kind of crap.
Hoosier JD
04-11-2005 19:18:50
 Re: 1950 JD B Miscellaneous Questions in reply to Arthur Driesse, 04-11-2005 17:20:41
Autolite plugs--best for not fouling. Unleaded gas is ok. If you want to use an additive, hot rod resto places (The Paddock in Knightstown, IN) carry a true lead additive. Mike
elcajonfarms
04-11-2005 22:00:56
 Re: 1950 JD B Miscellaneous Questions in reply to Hoosier JD, 04-11-2005 19:18:50
What would the correct Autolite plug be for this B (1950 model year)?
Duane Larson
04-12-2005 06:27:18
 Re: 1950 JD B Miscellaneous Questions in reply to elcajonfarms, 04-11-2005 22:00:56
elcajonfarms,
Autolite 3116 plugs. Autolite 388 plugs are resistor plugs - they have a built-in resistor to reduce rf interference and I prefer to use plugs without them. No two cylinder JD ever came with resistor plugs.
