JD 1219
JDJACK
04-11-2005 13:13:17
I understand this is the tractor board, but I am not getting any help on the implement alley.
Just bought a jd1219 haybine, the guy said that he replaced one of the splined shaft for one of the rolls, and didn't get the marks aligned back up correctly. Said that it makes a knock noise from the rolls not aligning up correctly. What is the correct way to adjust these? It doesn't have non-clog guards. About what would it cost to convert it, and can a bolt on section sickles, sickle be installed in it the way it is?
Thanks for any help. JDJACK
Mattf-8
04-12-2005 11:47:02
 Re: JD 1219 in reply to JDJACK, 04-11-2005 13:13:17
I replaced my non clog gaurds, some shims, some hold down clips and some bolts for about $220 on my 1219 if I remember correctly. I also replace the cutting bar for about another $90. I cut orchard grass and the non-clog gaurds are great! Hopes this helps. Mattf-8
Rodney A Johnson
04-12-2005 06:29:05
The 1219 should be much like my 1209. There are marks on the rolls that have to line up. You would need to releave the spring pressure and take apart the splined shafts..have to move the rollers apart..spin the rollers till the two marks match, then put splin shafts back together and retention the springs. A user's manual should have all those details on setting it up. Probably around 30USD at JD dealer.
Yes you can use the bolts to bolt on sickle sections. However, you need the high clearance sickle hold downs (only style you can buy from JD now if I recall correctly). I've replaced most of mine, but still using rivets. Quicker to use rivets if you replace a lot of sections at once...as I take the sickle out (remove every other guard..sickle slides out pretty easy then) and then use hammer and anvil to flatten the rivets. I use disk grinder and punch to remove the sections.
Regular guards are something like 14USD?...maybe more...been about a year since I bought new ones (ie. haven't gotten around to prepping mine for this year yet).
