All of my gears don't work all of the time
Deborah Banko
04-11-2005 09:01:44
I have a JD sx75 riding mower. It would only move in 7th gear before we replaced the secondary belt. Once it was replaced we had 4th -7th gears but not reverse or 1st through 3rd gears. We then replaced the primary belt and we had all the gears moving the mower. Took it once around the yard and the gears started slipping. Now I only have 4th-7th but is still slipping. Can someone help me with this?
Thank you for your time!
Debbie
DHunt
04-12-2005 04:31:31
 Re: All of my gears don't work all of the time in reply to Deborah Banko, 04-11-2005 09:01:44
Another shot in the dark...since it seems that you have a belt or belt-slipping problem look for an engine oil leak. I had an older rear engine mower get a main seal leak that would soak the belt pulley with oil and make it slip. If the engine stalls now, likely the belt is now bound up somewhere else.
Dieselrider
04-11-2005 18:39:30
I am not familiar with that machine but, it sounds like your idler pulley may not be putting enough tension on the belts. Like maybe it's hanging up on something or the spring is weak. Just an idea to check.
