Sucking oil into carburetor
BigD
04-11-2005 05:32:26
My '48 JDA is sucking oil from the air intake oil bath into the carburetor. What is causing this? Needless to say she blows black smoke and the plugs are always fouled up. If I can't find a fix for that, I'm thinking of removing the oil bath system and adapting a paper filter to the air intake.
BushogPapa
04-11-2005 19:06:08
 Re: Sucking oil into carburetor in reply to BigD, 04-11-2005 05:32:26
Could very well be that you have a bunch of Mud-Dauber nests plugging the air inlet tube, just above the dog-leg..above the aircleaner...
Shove a garden hose up from the aircleaner bottom...all the way to the top of the air-intake stack and see is you get a bunch of them out...water sure works well for this..!!
Ron..
dknarnd
04-21-2005 15:58:02
 Re: Sucking oil into carburetor in reply to BushogPapa, 04-11-2005 19:06:08
If you run water up in the air cleaner don't you run risk of getting water in the carb?
Also I did not notice an answer to cleaning the mesh at the bottom of the air cleaner. Can this be removed and repacked with something?
BushogPapa
04-21-2005 17:23:53
 Re: Sucking oil into carburetor in reply to dknarnd, 04-21-2005 15:58:02
With the bottom off the aircleaner, the water will just run down and out the bottom of the tube.. The air for the carb is drawn up the outer area with the mesh... You can take the airfilter canister off, and soak it in Mineral Spirits to flush it out, but it is probably not that dirty....assuming it has had reasonable maintenance...It comes off via three vertical bolts at the top of the aircleaner canister...
Ron..
720Deere
04-11-2005 12:30:41
You've gotten some good advice so far. Another thing to check is that you are using the correct weight oil in the cup. Those oil bath air cleaners are designed for a certain viscosity and level of oil. Sometimes multi-weight oils can cause these problems. I believe they were specified to use straight 30 weight oil.
WTW
04-11-2005 12:10:02
Most often seen when oil level is too high in air cleaner bowel usually caused by water in air cleaner. It will even smoke after oil level has been corrected due to oil saturated in filter mesh. Remove or empty bowel and let filter mesh drain overnight or longer.
BigD
04-12-2005 05:53:13
 Re: Sucking oil into carburetor in reply to WTW, 04-11-2005 12:10:02
Is there a way to clean the mesh filter?
bent
04-11-2005 07:27:34
My AR was doing that. The ventilator pump was pluged with dirt/oil/whatever sludge and the cast housing at the bottom of the intake was very restricted. I had to use a zip cut and remove the stack from the cast so I could get in there and clean it. Seems to be okay now, runs better too when it gets air.
bent
Dave NE IA
04-11-2005 07:09:43
I would be under the assumption the tube must be plugged, thus putting extreem vacume on the oil itself. Have you checked the owners manual, and certian the oil level is not in excess? it should have a mark on the oil cup. Does it suck all the oil out? I can't remember ever seeing this however, just the first thought that comes to mind. Dave NE IA
Big D
04-11-2005 10:49:58
 Re: Sucking oil into carburetor in reply to Dave NE IA, 04-11-2005 07:09:43
Dave,
I've kept the oil at or slightly below the mark on the cup. When you say the tube, do you mean the tube that goes into the valve cover? I'm new at this so I appreciate all the advice people are willing to share.
Dave NE IA
04-11-2005 19:32:56
 Re: Sucking oil into carburetor in reply to Big D, 04-11-2005 10:49:58
Mr. Big D, Perhaps the easy way to explain the plugged tube is to say --The up wind part before the air gets to your oil cup, and upwind of the carburator (between oil cup & carburator) as well. Don't ever be afraid to ask on this board as the gang are all user friendly. Keep us posted, and good luck. Dave NE IA
donmyeil
04-11-2005 07:01:27
assumeing you have checked the air cleaner for restrictions from dirt etc , are you overfilling the oil cup? just a thought Don
