720 Pony Motor Access
Tsmith1499
04-10-2005 21:54:07
Okay guys, give me a hint. Do I have to take the hood off of my 720 standard in order to get the air cleaner off of the pony motor? I tried every position I could think of today with no success. I am having a fuel delivery problem and can't get into the fuel shut off in order to see if it is clogged up. If I have to take it off I don't mind, but if I can get access to everything WITHOUT doing all that it would be nicer. Does the tube coming of the air cleaner going back into the motor come off the air cleaner or just out of the motor? Seems like that is what's holding me up. New to 720 deisels and pony motors. So expect more questions! Thanks, Tom
F-I-T
04-11-2005 11:51:00
 Re: 720 Pony Motor Access in reply to Tsmith1499, 04-10-2005 21:54:07
I agree with the others. Taking the hood off isn't all the big a job. Do pay attention to the hardware locations, because if you have everything original, there's quite a bit of it. If you don't, check against the parts book and get the proper bolts, bushings, and rubber bumpers when you go back together. It will all fit better.
Also, on my 70D, I removed the mesh form the pony aircleaner and replaced it with a tapered paper element that is used on some Tecumseh 6 hp engines. No oil dribbles anymore and the bottom is exposed so if anything gets damp it dreis out immediately. The element fits a JD 56 and 68 mower as well. About $3.00 at your local lawnmower shop.
Frank
Hax
04-11-2005 10:13:53
I'm new to the 720 also and I'm just getting around to messing with the Cranking Engine, after freeing up the right break, and working on the clutch, but I've taken the hood off, and it will be off until the little moter is running. It just seemed to cramped to work on it anyother way. I really like 720,and the big motor runs great, I'm just concerned about the Cranking Engine. Good Luck, Hax
720Deere
04-11-2005 12:38:41
 Re: 720 Pony Motor Access in reply to Hax , 04-11-2005 10:13:53
What problems are you having that are causing you concern over the cranking engine? F-I-T and some others here will attest that the pony motor is fairly easy to work on but can be rather expensive. Mine ran like a top but was on the outer edges of the service limits. Other than excessive smoke you would have never known that it wasn't healthy. The infamous waterpump seals gave out and that's what started my rebuild. I could have just replaced the seals and ran it the way it was for many years but my mind just doesn't work like that!
I've even heard stories of those little guys still running half decent on 3 cylinders after throwing a rod. The fickle little carb is the key to getting one to run good. They are very sensitive to adjustment. If you have any major concerns, just post them here. There is a good number of guys here with first hand experience with cranking engines.
Hax
04-12-2005 10:07:19
 Re: 720 Pony Motor Access in reply to 720Deere, 04-11-2005 12:38:41
I've been gathering up the igition parts, and I need a key switch with the resister, before I can test things out. But I am concerned about the water pump,{I had a friend who had trouble getting the seal, and the clearance correct}, and the general condition of the engine, due to it setting for some time. I'm not tight with money, but my wife is. I'm like you, I can't stand for something to smoke, or not be right, So I guess it's all the unknowns that will remain to be seen. I'm used to New Generation tractors, and some other makes, this is the first go round with a two cylinder. I'm sure I'll be yelling back. Later, Hax
Dan in Ohio
04-11-2005 06:48:56
Tom,
I have always taken the hood off when doing initial repairs on my 70's. Take a close look at the automatic fuel shut off. My 70 std had one on it, could not get it to work, so I by passed it and the problem was solved. Taking the hood off seems like alot of work but it will save you some headaches until you get the pony running well.
720Deere
04-11-2005 09:50:06
 Re: 720 Pony Motor Access in reply to Dan in Ohio, 04-11-2005 06:48:56
I've never sweated taking the hood of my 720. It only takes about 15 minutes and unless you have an expo paint job it doesn't harm anything. That 15 minutes is worthwhile when working on a pony motor.
