jdemaris
04-11-2005 06:00:12
Re: JD 1010 horsepower in reply to gasmith, 04-10-2005 20:27:04
Gas engine for the 1010 was rated at 36 horse in Nebraska testing, but I don't believe it. Diesel . . . more believeable. Diesel has inherently less horsepower than an equal sized gas engine, but the 1010 diesel has 144 cubic inches, being the same engine size as a 2010 gas engine. The 1010 gas engine is about the same size as a 420 two cylinder Deere. 1010 gas is 115 cubic inches and the 420/430/440 are 113 cubic inches. 420 was rated at 27 horse at 1850 RPM, same size engine in the 440 was rated at 32 horse at 2000 RPM, and the 1010 36 horse at 2500 RPM. So, sounds good on paper - more RPM, more horsepower and the 1010 has four small cylinders instead of two big ones. Try to get the power though. We rebuilt and sold new many 1010s and I've never seen a single one put out the rated power on the dyno. I don't remember now what exactly we did get out of them on the M&W dyno, but it was not 36. I also own a couple of 1010s, nice running tractors but pretty gutless. In fact, I've been thinking about removing the 115 cube gas engine from my 1010 crawler and bolting in a 2010 gas engine. I think/hope it's bolt-in swap. The 2010 gas engine at 144 cubic inches is rated at 47 horse. Probably make a much nicer machine out of it, and the engine change would not be visable. Back to the 36 horespower rating, try comparing a "36 horse" 1010 crawler to a Deere 350 crawler rated at 39 horse - there is quite a difference. If comparing wheel tractors, compare the 1010 gas to a 1020 gas that uses the same engine as the 350 gas crawler (135 cubic inches). Going by the Nebraska ratings, the 1010 should be close to equal to the 350 or the 1020 - and it's not. Don't get me wrong, I like 1010s - but I've always found the advertised horsepower to be elusive.
