1010 clutch problems
lloyd sc
04-10-2005 19:54:06
Hey guys, I did look in the archives & found same problem, but no answer. Short history; replaced clutch disc & pilot bearing, rebuilt pressure plate, turned plate & fly wheel, cleaned & lubed shaft etc. clutch adj. cam fully engaged. clutch doesn't disengage, has 3 to 4 in freeplay on pedal (same as before repairs started). Where do I start?
buickanddeere
04-10-2005 21:23:40
 Re: 1010 clutch problems in reply to lloyd sc, 04-10-2005 19:54:06
What clearances did you set the pressure plate fingers at? Live pto or trans driven?
lloyd sc
04-15-2005 21:43:43
 Re: 1010 clutch problems in reply to buickanddeere, 04-10-2005 21:23:40
Live pto? always confuses me. It will (with a bush hog) continue up a tree with the clutch in if that helps. On setting thr pressure plate fingers, I didn't. Just assumed the rebuilders did that...
