JD 1010 brakes
gasmith
04-10-2005 19:49:57
I have little or no brakes. Assume new brake bands are needed. Any other thoughts or suggestions?
jdemaris
04-11-2005 06:18:10
 Re: About the adjusters in reply to gasmith, 04-10-2005 19:49:57
One additonal comment to what I already posted. Those adjustment scews usually accomplish nothing as far as improved braking is concerned. They take out free-play and pedal travel. 1010 brakes usually don't wear very much, they just get glazed after getting used a couple of times, and then - with no friction - hold up quite well since they don't do any work. If somehow you DID actually get them to wear - to the point the pivot balls were coming out of their respective ramps, only then would the adjustment help with the braking.
jdemaris
04-11-2005 06:09:37
 1010 had no useful brakes - ever! in reply to gasmith, 04-10-2005 19:49:57
Yeah . . . 1010 and 2010 brakes on wheel tractors never worked well - in fact, barely worked at all. We sold them new. First time some poor farmer hooked a hay wagon behind the tractor and went down a hill - he went for one heck of a ride. Good flat-land tractor. Deere made some minor attempts at improvements on the brakes - and finally - the biggest improvement was dumping the entire tractor series and introducing the 1020 and 2020. We achieved slight gains by sending out the brake parts to a machine shop and having them grooved - but as I said, the gains were modest. Improved to a point, that coming down a steep hill - with nothing hitched to the tractor, you stood a reasonable chance of stopping if you stood on the brake pedals and you weighed over 200 lbs. Maybe now, years later, someone has come up with something better? Or, maybe at this point, no one cares.
buickanddeere
04-10-2005 21:25:06
 Re: JD 1010 brakes in reply to gasmith, 04-10-2005 19:49:57
Disks, two per side. Have the brakes been adjusted?
gas2184
04-11-2005 05:22:50
 Re: JD 1010 brakes in reply to buickanddeere, 04-10-2005 21:25:06
It does have power steering. The operator's manual has a drawing in it that I think shows the setscrew and locknut that you describe. Assume this is the same whether you have power steering or not. I will give it a try. Thanks.
lloyd sc
04-10-2005 19:58:53
Check out 1010 adj. brakes below, also archives are really helpful.
