JD 1010 loose steering
gasmith
04-10-2005 19:47:29
Just bought a 1010. The steering is loose. Is there an adjustment in the gearbox or is it more likely to have worn out parts in the gearbox?
buickanddeere
04-10-2005 21:28:51
 Re: JD 1010 loose steering in reply to gasmith, 04-10-2005 19:47:29
Manual steering? Jack the front wheels off the ground after accessing the top of the steering box. Adjust the set screw down until the steering gets grabby and binds a bit through a full right left turn. Fill with combine corn head grease mixed with some Slick 50 or other wonder glop.
gas2184
04-11-2005 05:31:53
 Re: JD 1010 loose steering in reply to buickanddeere, 04-10-2005 21:28:51
It does have power steering. The operator"s manual has a drawing in it that I think shows the setscrew and locknut that you describe. Assume this is the same whether you have power steering or not. I will give it a try. Thanks.
