Brake Lining problem on a JD B
Wayne from Iowa
04-10-2005 18:17:57
I am relining the brakes on a JD 1945 B for a friend. I am wondering why a full lining will not go in the brake drum?? There is not enough clearance on the adjusting end of the shoe to use the full lining. They will not retract enough to slide them in the drum. Guess I will just have to use three forths of the lining unless anybody has any ideas.
Wayne from Iowa
04-11-2005 10:47:47
 Re: Brake Lining problem on a JD B in reply to Wayne from Iowa, 04-10-2005 18:17:57
Thanks for the ideas and imput. I ended up cutting the linings like the old ones were. Now they went back together ok. Maybe just the 45 B had this quirk?? Anyway the B will be fine with a little lining off of it.
Mike M
04-11-2005 09:54:00
I don't know exactly why but I had that very same problem on my '45. I thought I'd put in the full linings like the later ones had. I had everything ready to go back together and that drum would not go on.I just ended up takeing a hacksaw and cutting them off to match the originals.There made short for a reason.
Ravgardner
04-11-2005 04:39:39
Wayne, Your problem is unique and puzzling. I have never heard of this problem before. I've relined brakes on both a B and an H and found plenty of room to slide the drum over the shoes. There must be something holding the shoes apart caused by how they are assembled. There is a small chance the linings are too thick. If you measure them, I'll measure my spare linings an share that with you. But I have to think there is something wrong about the way they have be put back together. Study where the adjusting pins touch the adjusting bolt. The angled ends of the two pins should almost touch when in position to put the drum back on. If not, then make adjustments so they come almost together.
