HEATING PROBLEM MAYBE???
5th Wheel
04-10-2005 18:02:59
I have a "41 BModel and a 51 M, the M seems to heat up quite a bit more than the B. When I got the M, it had 100% green antifreeze in it, I guess they wanted to match the paint! At that time it got pretty hot or at least I could smell the anti. I flushed it out for a while and put all water in it and that helped a bunch, but it still gets hotter than the B. Is there a problem??? Thanks
jd51mt
04-11-2005 14:39:20
 Re: HEATING PROBLEM MAYBE??? in reply to 5th Wheel, 04-10-2005 18:02:59
5th Wheel
Your "M" should run around 230 degrees or a little higher. It should hold 3 1/2 gallons. Do not use just anti-freeze in it.
MIke
old
04-11-2005 09:08:49
You may have something gloged in the system. I'd do a vinegar flush. Drain the system fill with vinegar and run it for an hour or so to get it warmed up good. Let it cool and then flush it out with water, on the last tractor I did this to I was able to make up a thing that would go in the side of the block so I could back flush it with a hose. I hooked up the hose turned it on and walked away for a couple hours and just let it clean out the rad/engine. Hasn't got hot since
