4020 question for S. C.
Al Epp Waldo
04-10-2005 18:02:04
I have a 66 4020D also and the fuel gauge doesn"t work. The oil light only works if the headlights are on.I read your post about the ground wire on the left battery. I just checked my tractor and it doesn"t have a ground wire but I noticed a wire end under a bolt holding the clamp for the remote hydraulic line. Is this where the ground wire is supposed to go? And it goes to the positive post on the battery, right?
not sc-msb
04-10-2005 21:30:11
 Re: 4020 question for S. C. in reply to Al Epp Waldorf Md , 04-10-2005 18:02:04
The ground wire goes to the rear post(positive ) on the left side battery and it doesn't make any difference where it attaches so long as it is the transmission case.And the size of the wire makes little difference unless it is maybe 14 guage or less.I have seen people use all kinds of wire including copper Romex cable wire but its best to use a fuse holder with a slow blow fuse in it.
