Shift gates, 46 model B
Ken Tabor
04-10-2005 15:14:28
I am near assembling the shifter after replacing all the bearings in the transmission. The sift gates have dimples in the sides of the gates. Do these belong there as a detent or are these wear areas. If they are wear areas, would it be beneficial to weld them flush again? The bulb on the shifter shows no significant wear. Ken
Mike M
04-10-2005 17:40:52
 Re: Shift gates, 46 model B in reply to Ken Tabor, 04-10-2005 15:14:28
I think you are refering to the inside area where the lever contacts ? These were flat inside when new. I have built them up with a nickle rod made for welding cast iron and then ground them back flat. Make sure your lever still passes through them when done.
