730 DIESEL PUMP PRESSURE
NigelB
04-10-2005 12:29:22
tractor only injects on one cylinder sporadically changed over injectors to eliminate that and there fine, i think the pump pressure isn't high enough and there isnt enough fuel in the injector houseing to deliver enough fuel for the second injector. so the question is can you messure the pump pressure via a gauge on the filter housing and get a reeding of 18-28psi when cranking over the starter(direct start) regards nigelB
buickanddeere
04-10-2005 15:18:10
 Re: 730 DIESEL PUMP PRESSURE in reply to NigelB, 04-10-2005 12:29:22
Has there been any re-shimming of the relief spring/ball? The fuel forwarding pump goes to bypass when at rest.Gravity feeds the injector pumps for the first few snorts until the forwarding pump builds pressure. And then pushs the bypass vent closed. Overshimming will put the pump onto bypass all the time.
With the late 720 and 730 anti-reverse peanut cam. Fuel forwarding pressure of 45-55 psi is desired if memory serves. I still haven't found 1/2 my service manuals after moving two years ago. What is the running fuel forwarding pressure. Any fuel leaks past the pump shaft seals?
NigelB
04-10-2005 22:35:45
 Re: 730 DIESEL PUMP PRESSURE in reply to buickanddeere, 04-10-2005 15:18:10
Tryed shims in the pump to see if that doesn,t make a differance,it has a late return valve to fuel tank (small hole) tryed on a old pressure valve type no change there eather,how would you tell if a seal had gone,would you look for fuel in the sump! regards nigelB
buickanddeere
04-11-2005 05:03:52
 Re: 730 DIESEL PUMP PRESSURE in reply to NigelB, 04-10-2005 22:35:45
Over-shimming just makes the fuel pressure lower instead of higher. May have to bore and hone the valve body oversize. Then make an oversize dia plunger. What pressire will the pump make with the bypass plugged and an ajustable return valve plus a pressure gauge plumbed in.
