Converting a 24 v into a 12 v starter
ed welsh
04-09-2005 22:38:35
A local starter shop says he can take my 24 v and change it to a 12v by switching the brush and solenoid .How is this done
Dale in IN
04-10-2005 09:21:21
 Re: Converting a 24 v into a 12 v starter in reply to ed welsh, 04-09-2005 22:38:35
ED: If you are thinking about doing this to a 4020 you are asking for a lot of rebuilds and a lot of battery replacements. I did the thing you are talking about several years ago and I had nothing but trouble. I was having to have the starter rebuilt about every 2 years and replacing the bateries about as often.
A JD Mechanic told me to go and get a starter off of a 4320. They are about 4" longer and have a lot more torq. I did that and have not had to have the starter worked on sense. The starter will bolt right up and you have plenty of room for it. Then I Made a frame and bought 2 of the heavest 6V John deere bateries that they had at that time.And I set them right up beside the starter and hooked them up in series. I have also not had to replace the batteries every 2 years as I was before. The ones that are in there now have been in for 4 or maybe 5 years . The tractor had set all winter and I changed the oil about a week a go . When I hit the starter the engine startered before it had made a complete revolution. Then you will also have to change your Generator or go to an alternator.
John T
04-10-2005 06:56:34
Ed, while I agree its possible to convert a 24 to a 12 volt starter by a competent shop or rebuilder, I DONT THINKS ITS QUITE ALL THAT EASY as a brush and solenoid change. Seems to me the Field windings would have to be changed for sure (higher field current needed), maybe the armature with brushes to match for different comutator spacings or sizes or current, then the solenoid I agree. In order to develop as much horsepower at half the voltage, the currents gonna have to be increased is why I think its not all that simple and probalby NOT inexpensive. Goes to the old saying "Theres no free lunch" which holds true in energy principles.
Ken of Kenneths Classic Genertors down there in Texas would be where I would check for the best answer, Im decent in theory but dont operate a starter repair shop nor have the knowledge he has.
I would look into repairig the 24 volt system as they are good IF WORKING lol
Ol John T
Gerald J.
04-10-2005 08:46:18
 Re: Converting a 24 v into a 12 v starter in reply to John T, 04-10-2005 06:56:34
Its possible in the series motor of the starter that 12 and 24 volt starters used the same armature and the same field windings. But wired the two field poles in parallel for 12 and in series for 24 volts.
It is also possible that the 12 volt armatures are common enough that the shop is willing to swap a 12 volt for a 24 volt armature. I know that a replacement 12 volt armature for the starter of my gas 4020 wasn't all that bad when a relay stuck and the old one threw the windings out of the slots.
Back in the late 40s there were articles and ham radio magazines about adding a brush holder to the input side of a dynamotor moving it 90 shaft degrees from the original position and getting normal output from the high voltage winding while applying 12 volts instead of 24 to the input. Seems to me that makes 1/4 the primary armature winding take most of the current with the rest taking much less than normal. And seems to me the commutation comes at a high current point on the commutator rotation to cause lots of sparks. When the 24 volt dynamotor in surplus could be bought for less than its value in scrap copper (due to the effort required to separate the copper from the cores) winding damage wasn't much of a concern.
I'd expect the cold cranking amps drawn by a 24 volt starter on 12 volts without modification would not crank a cold engine.
Gerald J.
John T
04-10-2005 09:08:19
 Re: Converting a 24 v into a 12 v starter in reply to Gerald J., 04-10-2005 08:46:18
Gerald, I also dont think 12 on a 24 would crank her cold. Thats an interesting possibility to run the Fields in paralell instead of series, similar to how one connects AC motor windings to accommodate for 110 or 220 operation, but its still like we suggested more complicated then just changin brushes n the solenoid to change from 24 to 12 like the original poster mentioned.
Seems that in high torque application like a starter, as opposed to Generators where the Armature and Fields are in paralell, the Armature and Field are in series, I think we talked aobut this before but I done went n forgot what you told me.
Take care
John T
Gerald J.
04-10-2005 11:14:24
 Re: Converting a 24 v into a 12 v starter in reply to John T, 04-10-2005 09:08:19
Funny you should mention TORQUE. The series motor used for starters and for electric locomotives (mostlly) as well as street cars and diesel electric locomotives (except for one line in Italy and very recent production) is primarily a torque motor. It creates torque by current and the shaft speed is determined by the load. The lighter the load the faster the shaft speed. Long about a couple horsepower of rating, the unloaded speed can get high enough to sling the windings out of the armature.
It would be very practical for a starter maker to design a 24 volt starter and a 12 volt starter with the same field coils. Just wire them in series with each other for the 24 volt case and in parallel for the 12 volt case. And since those series (connected in series with the armature) are carrying full motor current, a reconnection might not be trivial, depending the design. If I was designing the pair I sure would consider trying to use common parts because the plant would be making many more 12 volt starters for cars and tractors than 24 volt starters. Anything I could use in common could improve profits from the larger scale of production and the reduced number of different parts in inventory. Maybe not a reduced number of parts but one big bin instead of a nearly big bin and a small bin. To say nothing of lesser confusion on the production line of whether the parts were for 12 or 24 volt use. And there can be economy of scale in purchased materials like the strap to wind the field coils.
Then maybe the same armature for gas starts on 12 volts can handle the increased current and torque for diesel starts on 24 volts for a while.
Motor design is not an absolute where you increase the current 11% and the motor instantly fries. Its more of one where you increase the motor current 50% and the motor lifetime (as the added heat ages the insulation) goes down (unless you get it so hot the solder in the commutator melts, then you have to consider the cost of welding versus soldering). You have to trade materials and manufacturing cost with performance and with motor lifetime. Starter motors run a few seconds when everything works and on a farm tractor maybe only a few times a day (presuming it starts once in the morning and works all day). New generation tractor charging systems presumed only a couple starts and several hours of running per start, else they didn't keep up. The trade off was generator cost and battery life. JD doesn't buy new batteries. 4020 starter and generator were not oversized.
Gerald J.
buickanddeere
04-10-2005 15:42:23
 Re: Converting a 24 v into a 12 v starter in reply to Gerald J., 04-10-2005 11:14:24
A DC motor with the fields in parallel with the armature is a shunt motor. Great speed regulation but starting torque is lousy compared to the series motor. As current goes higher in series motor the field current also goes higher. That increases the armature torque. However if a series motor is ran unloaded. The few heavy field winding turns do not produce enough back emf to limit armature current. This is why a DC crane motor, diesel train traction motor, subway train motor, electric drill, skill saw, sewing machine motor etc. Will take off and race uncontrolled without a load. The larger motors will over rev until centrifugal force tosses the windings out of the armature slots. Torque is a function of current. 12V on a 24DC motor will provide 1/2 the torque and 1/4 the HP. As for re-winding a 24V starter for 12V. There likely won't be enough room inside the case to get enough turns of large enough wire. 12V will only push 1/2 the current through the same sized wires. Or the wire size will have to be doubled. Now unless there are twice as many winding of this twice as big 12V wiring. The starter performance will drop. Ed, what is your motivation to change from 24 to 12V? How familiar are you will electrical circuits and how deep are your pockets? Is this tractor a hobby machine of the prime HP for your primary income? The change from 6V to 12V was made for good reason. The aviation industry and military use 24V for a reason too. We also avoid 120V motors in industry when we can use 240 instead. Or 480 even 600 instead of 208.
Gerald J.
04-10-2005 18:35:13
 Re: Converting a 24 v into a 12 v starter in reply to buickanddeere, 04-10-2005 15:42:23
I'm not talking about fields parelleled with the armature. I'm talking about the two field poles wired in parallel with each other and in series with the armature for 12 volts and the field poles wired in series with each other and in series with the armature for 24 volts. That way there's two conductors in parallel in the field coils for 12 volts but just one carrying the hopefully reduced current at 24 volts.
If one can presume the 24 volt current is half that of the 12 volt current for the same shaft torque, then it takes the same room for twice the turns at half the current or half the conductor cross section. The field flux is the same for n turns and I amps or for 2n turns and I/2 amps.
I'm not sure of the 24 volt motivation for military vehicles, especially jeeps. 6 volt tractors and automobiles worked adequately for their time providing regular attention was applied to keeping the battery posts clean. Greater loads like air conditioning made going to a higher voltage like 12 volts more attractive. The cost of the added battery cells was countered by the lower cost of all the vehicle wiring. I'm not convinced 24 volts is all that much better, though the JD diesels with 24 volt systems did run a few years without troubles unless the users added unbalanced accessories to mess up battery charge balance. The original generators were intended for tractors run all day for each start not to recharge the battery in ten minutes.
I've rewound a generator for twice voltage. Later I learned I worked too hard. But it did work adequately.
Gerald J.
jdemaris
04-10-2005 06:33:21
I don't believe it is possible. Are you confident this guy knows what he's talking about? The higher the voltage, the smaller the wire that is normally used in the windings. Because of that, 6 volt starters have heavier wire than 12 volt starters, and 12 volt starters have heavier wire than 24 volt starters, etc. Subsequently, that is why a 6 volt starter handles 12 volts just fine - it is overbuilt. And, a 12 volt starter can handle 24 volts. But, feeding low voltage has the inverse effect. Putting 12 volts to a 24 volt starter, i.e. 1/2 the normal voltage - perhaps 9 volts at cranking instead of 18-19, but requiring equal wattage, means twice the amperage is being drawn through wire inadequate to do the job. It does not work. One possible exception is, maybe some later starters used the same size wire in the 12 volt and 24 volt models? I've never seen it, but I haven't seen everything.
txgrn
04-10-2005 07:17:01
 Re: Converting a 24 v into a 12 v starter in reply to jdemaris, 04-10-2005 06:33:21
There is another question out there (either ttalk or tool talk)about the converse; running a 12v starter on 24 v. I answered that one positively and agreed with the guy supplying info to the person asking the question.
I agree with both you on this. I personally doubt whether or not 12v would spin the starter fast enough to spin the Bendix out and engage the flywheel.
Mark
John T
04-10-2005 07:09:38
Yo jd, looks like we agree, there IS no free lunch eh. I wouldnt be too afraid to throw 24 volts on a 12 but NOT 12 on a 24 lol
John T
