1941 A Very low oil pressure.
railroadgoat
04-09-2005 19:37:15
Took the oil pump out, cleaned the sludge out of the crankcase and replaced the gaskets, oil filter, and oil, 30 wt. 8 quarts. Did replace the oil pump coupling. Replaced the oil gauge and gasket on top cover. When I started it, oil pressure was between low and stop. What should I do or try ?? Can I run the tractor with the crankcase cover off, to watch inside, or am I going to create a terrific mess ??
Pat Browning
04-09-2005 21:27:49
 Re: 1941 A Very low oil pressure. in reply to railroadgoat, 04-09-2005 19:37:15
Man-oh-man! Run a JD "A" with the crankcase cover off! Now, that would be a show. Get your camera ready! You will hve oil flying everywhere for a short while, and then there would be less, and less, and less --- and finally it would cease to fly -- after it had flown mostly everywhere! No, don't run the tractor with the cover off. Have a known good gauge, run to see what you have. then do something about it.
For an early "A" (prior to 584000) to adjust the pressure, you remove the cover and and turn adjusting screw CW to increase pressure to a value between 10 & 15 psi. DO NOT ADJUST WITH ENGINE RUNNING.
For a later "A"(584000 & up) to adjust oil pressure, you remove a pipe plug or a cap nut from right side of crankcase under the pulley. This gives you access to the adjusting screw; turn CW to increase pressure. DO NOT ADJUST WITH ENGINE RUNNING.
And I will add -- DO NOT OPERATE ENGINE WITH COVER OFF, OR WITH PLUG OR NUT REMOVED.
You should have from 10 to 15 psi with engine running at operating temperature (190 degrees).
I hope this helps. (PatB)
JAYSON JEWISON
04-12-2005 22:40:06
 Re: 1941 A Very low oil pressure. in reply to Pat Browning, 04-09-2005 21:27:49
GO AHEAD N RUN'ER. DID WITH MINE & HAD SOME MESS BUT NOT VERY BAD. ONLY NEED 1/2 A MINUTE. COOL TO LOOK AT ALSO. REMEMBER AT LOW IDLE IT TURNS SO SLOW YOU CAN SEE EACH FAN BLADE GO BY & THATS FASTER THAN CRANK SPEED. YOU CAN CLEARLY SEE BOTH ROD NUT OR ANYTHING ELSE YOU WISH TO SEE AT IDLE SPEED. STARTED MY 45A BY HAND SEVERAL TIMES TO ADJ. PSI W/OUT HAVING TO REINSTALL STARTER/TOP COVER. YOU COULD RUN FOR SEVERAL MINUTES B4 RUNNING OUT OF OIL. (2 GALLONS IS A LOT!!)
mattd
04-09-2005 19:47:32
get a gauge with numbers and make sure it is about 15 psi. some of them new gauges have been known to be off.
matt
