70 clutch driver removal
Randy Stoudt
04-09-2005 08:35:44
With just a puller I cannot get the driver off of the tapered spline. Will it be ok to heat the driver with a torch to expand it?
720Deere
04-10-2005 07:25:32
 Re: 70 clutch driver removal in reply to Randy Stoudt, 04-09-2005 08:35:44
That 70 clutch driver should have 2 each 1/2"bolt holes in the middle near the hub. when you put bolts through them they push against the pulley and push the drive off. Maybe if you have those bolts, they will help along with the pressure of the puller. A little heat won't hurt anything but don't get carried away and try not to heat the crank.
Randy Stoudt
04-10-2005 14:44:28
 Re: 70 clutch driver removal in reply to 720Deere, 04-10-2005 07:25:32
If I push with those bolts will I damage the clutch disc?
F-I-T
04-10-2005 16:35:58
 Re: 70 clutch driver removal in reply to Randy Stoudt, 04-10-2005 14:44:28
Those holes 720 Deere is referencing should position the bolts to still seat to the pulley backside and clear of the linings.
I use them all the time on my 70 D.
Frank
farmall puller
04-10-2005 06:11:55
We got one off by putting all the pressure we could get on it with a puller and hitting it with a hammer and it finally came off
