Help! Re Powertrol clutch
MarksJD730
04-09-2005 07:24:33
Is it possible to remove the powershaft clutch WITHOUT having it in the engaged position? Mine is stuck in neutral and everything I have tried (and some of these things have been dramatic) cannot get it into the engaged position. Manual says put it in engaged and remove cover - jsut can"t do it! All thoughts appreciated
Mark
MarksJD730
04-09-2005 17:12:09
 Re: Help! Re Powertrol clutch in reply to MarksJD730, 04-09-2005 07:24:33
Hurray! Got it apart! I need to replace the oil seal - gear lube in the clutch housing. This other problem I need to correct is this verh hard operation of the clutch. You cannot operate it using the foot pedal - jsut too stiff. Just before I got it it had new plates put in the clutch. What should I look for? Could it just be the adjustment? How would I check this before putting it back together? (It is a 730 diesel)
Thanks
Mark
greenmech
04-09-2005 21:39:51
 Re: Help! Re Powertrol clutch in reply to MarksJD730, 04-09-2005 17:12:09
Mark, there should be a nut with a keeper locked in, you have to hold it back while you turn the nut. Sounds like it was too tight when your problem started. Your IT manual should show how to adjust. The discs need to be lined up before assembly. Ron Mn.
greenmech
04-09-2005 08:24:13
I believe you can remove the live pto from the tractor in the disengaged possition. When you install it , how ever it must be engaged and lined up with the splines. I assume this is for a 730.
