A Model front wheels
Dave in SV
04-09-2005 05:56:02
I could use some help figuring out what part number wheels go on the front of my late A (serial number 634007). One of mine is warped pretty bad, so I think I should replace it...? The parts catalog lists a few part numbers, depending on how many plys the tires are...???
Of course, the next thing is... finding one!
Help will be appreciated
Duane Larson
04-09-2005 14:31:21
 Re: A Model front wheels in reply to Dave in SV, 04-09-2005 05:56:02
Dave,
Your A would have come with either JD1268R or JD1274R front wheels. Both are reversible and are hard to distinguish from each other except by the part number stamp. The 1268 has a 4.00E-16 rim size, while the 1274 has a 4.25K-16 rim size. The difference is if you cut a slice through the rim and compared the profiles E and K, they would be different, as well as the weight. The 1274 is a heavy duty wheel designed for use with loaders and heavier front end mounted equipment. Either one would be fine, and if you mixed them, few people would notice the difference. Both take a 5.50-16 tire. Note that both front wheels come in versions which have the rim either riveted (with 3 rivets) to the center wheel, or spot welded to the center wheel. The riveted versions came earlier, and my guess is sometime during 1951 the change was made to spot welding.
Dave in SV
04-10-2005 10:50:21
 Re: A Model front wheels in reply to Duane Larson, 04-09-2005 14:31:21
Thanks for the great info. I feel a bid stupid here... didn't even THINK to look at my wheels for a stamped part number!
