A Model trans/rear end lube
Dave in SV
04-09-2005 05:42:32
I noticed that the lube in my trans/rear end compartment has a creamy pink tint to it. I'm guessing this means water is in there?
I've read suggestions about flushing this compartment with "flushing oil". Is this really a good idea? What is used as "flushing oil"?
billde
04-09-2005 07:37:11
 Re: A Model trans/rear end lube in reply to Dave in SV, 04-09-2005 05:42:32
Dave, I doubt you can even buy flushing oil anymore. I save my hydraulic oil when I change it in other tractors and use it to flush. The manual says flushing oil or kerosine. I flush every [new] tractor when it comes home. Just be sure to let your A drain well after flushing, then refill with 90 or 140.
Dave in SV
04-09-2005 10:03:12
 Re: A Model trans/rear end lube in reply to billde, 04-09-2005 07:37:11
Thanks for the reply. 90 or 140 what? Is that thick oil? If so, is it something special for this use?
billde
04-09-2005 17:19:36
 Re: A Model trans/rear end lube in reply to Dave in SV, 04-09-2005 10:03:12
Dave, what you need is GL5 or gear lube. You can buy 80-90 wt or 85-140wt Yes it is very thick oil, if you are using your A for parades and all the seals are good use 80-90, but if you plan on working the tractor I would use 85-140. It should take about 8 gallons, any auto supply store should be able to get it for you, or go to Deere.
Dave in SV
04-10-2005 10:57:43
 Re: A Model trans/rear end lube in reply to billde, 04-09-2005 17:19:36
Thanks.
I will use my tractor for fun... parades, hayrides, etc.. I don't really know what shape the seals are in, but I guess I should go with 80-90? And since I don't have hydro oil, I'll use kerosene for flushing?
Again, thanks for the help!
