4020 diesel headlights
S. C.
04-08-2005 23:32:11
I've got a problem with my '66 4020 that is about to drive me insane. The two outside headlights and the dash light won't work. I'm not getting any voltage to the battery A terminal on the light switch. I am getting voltage to battery B terminal and the inside headlights, the tail light and the blinker on the left fender all work. A couple years ago I replaced every wiring harness on this tractor and after I finished, everything worked perfect so that is why I'm thinking it has to be something simple that I'm overlooking. Something else I've done is check voltage to ground on the terminals on the starter solonoid. The brown wire to ground I'm reading 24 volts. The blue wire to ground I'm getting 0 volts. I'd sure appreciate any input on this. I know this is just a minor problem but it drives me nuts when I can't figure out why something won't work. I hate this 24 volt system. Thanks for any help.
buickanddeere
04-08-2005 23:50:03
 Re: 4020 diesel headlights in reply to S. C. , 04-08-2005 23:32:11
A and B are each supposed to be 12V to chassis. One -12 and the other +12V to chassis. The 24V & 0V to chassis is the vital clue. The wire from the batteries "mid point" to chassis is open,broken, melted or the fuse blown. It's possible a wiring harness short or a monkied up attempt to boost start, opened the ground wire. Could be a "grounded starter,generator or regulator to The "A" lead somewhere between the battery and the switch could be open as well. Do you have a mulimeter to trouble shoot with?
S. C.
04-09-2005 09:10:05
 Re: 4020 diesel headlights in reply to buickanddeere, 04-08-2005 23:50:03
I finally figured out what the problem was. Somehow the small ground wire that hooks up to the left battery got put on the negative post instead of positive. I just happened to catch that looking at the wiring diagram again this morning. Probably lucky I didn't fry something. Now all my lights are working, even the oil pressure light and the fuel gage. One good thing from all of this is that I FINALLY understand how this 24 volt system works. Thank you for your help.
