430W--how get arms off rock shaft
Roger Bultman
04-08-2005 15:36:06
I am hoping to stop leaking out the rockshaft by replacing the seals. But how in the world do I get the arms to come off the shaft? No room for a gear puller? Won"t pry or pound off. What"s left to do?
Any advice will be GREATLY appreciated.
Thanks,
Roger
Henry J
04-08-2005 18:46:51
 Re: 430W--how get arms off rock shaft in reply to Roger Bultman, 04-08-2005 15:36:06
Roger
Heat then let cool and try a 10 lb sledge on one side as a bumper and hit the other side of the arm where it slides on the shaft with a 4 lb hammer.
Also If I remember you may be able to get a three jaw puller on the arm, the pressure/pull from it when applying the persuader did it on mine.
oops forgot, apply your favorite snake oil. Kryoil is mine.
Also on mine I got by with just doing the seals on one side. However with new seals the left sides still leaked like a sieve. I then changed the bushings (megabucks)and it was like new on the second go around.
Roger Bultman
04-08-2005 18:53:41
 Re: 430W--how get arms off rock shaft in reply to Henry J, 04-08-2005 18:46:51
Henry J, thanks for the advice. I did get them off by just hitting harder. Worried I'd break something.
Now, how do I get the rockshaft housing off the tractor. Any ideas to help me?
Thanks.
Roger
Wayne in Tn.
04-09-2005 02:31:41
 Re: 430W--how get arms off rock shaft in reply to Roger Bultman, 04-08-2005 18:53:41
Roger, I always remove the whole unit from the tractor and get it on the workbench when servicing the lift. But if you have some help to hold the housing up it can be removed on the tractor. Remove the 4 long bolts at the rear and the 2 short ones from the front. Then slip the housing back about 3 inches and remove the keys from the 2 control rods and slip them off the pins.
Roger Bultman
04-09-2005 04:01:35
 Re: 430W--how get arms off rock shaft in reply to Wayne in Tn., 04-09-2005 02:31:41
Thanks, Wayne. Based on advice here and from the Rummy discussion board I plan to take the tom off as well.
I might as well go through the tom unit also. More work but as long as it's apart I might as well do it.
Roger
