H PTO backlash
J.P.
04-08-2005 14:08:58
Does anyone have specs. on what the backlash at the PTO should be on a '41 mode "H"? Thanks, jph
Pat Browning
04-09-2005 18:08:23
 Re: H PTO backlash in reply to J.P., 04-08-2005 14:08:58
This is a difficult one. The I&T Shop Service Manual gives us a criteria in the range of from 0.006 to 0.010, and this adjustment should come after you have the bevel gears in heel-to-heel register. The backlash is set by varying the thickness of the shims between the power shaft S/A bearing housing and the H599R cover.
For tractors now 60 years old and sometimes more, to get this type of adjustment right tight is to set the stage for those gears to chew each other up. At this stage of the game, I recommend you set back lash so that you have "discernable movement" of the PTO shaft when the PTO shifter is engaged. There should be just a tad of looseness, not sloppy -- just so that you noticed there is some. (PatB)
