Be Damn Careful
Goodwrench
04-08-2005 12:44:01
If you follow this procedure, make certain you (nor anyone else) is in close proximity of the lines while cranking, as the pressure emitted from fuel pump is strong enough to inject the fuel under your skin. This condition will lead to gangrene & loss of appendages, if infection doesn't set in as well. Deere has trained their techs on the danger & yet some still are injured in this fashion. Safer method would be to bleed pump, filters & lines (if necessary) via priming pump. Takes more effort, but is much safer.
