620 exhaust
JD 4020 3020
04-07-2005 19:47:00
Somehow the 620 we still have sitting around had the cast block that connects the muffler to the exhaust pipe broke. This was done years ago and was never fixed, unless you call using wire "fixing". Now that I want to spruce it up a bit(paint and so on) Deere tells me that this part is no longer available. Guess it should have been fixed properly when it was broke. Anyways does anyone know of a aftermarket source for these, or is a salvage yard my best bet? Anyone have a clue what one of these is going to end up costing me?
Randy L
04-08-2005 04:50:37
 Re: 620 exhaust in reply to JD 4020 3020, 04-07-2005 19:47:00
I had a 60 with the same problem, it took a while but I did find NOS top radiator castings. I had it shipped from California to Michigan for $247.00 they had more then one at that time (three years ago). Keep looking you can find them or go to salvege yard. Good Luck
Woody [NE]
04-07-2005 20:09:57
I have a 620 that the casting is broken on too. Mine was welded and is a bit crooked. All was done before I got the tractor. This casting is also the top tank of the radiator too. Salvage yard should be a good source, but think it would be quite a job to replace. Maybe you could find someone to weld, would be hidden by the hood. That's 3 cents worth.
Woody [NE]
