70 gas wiring problems
bruddies pop
04-07-2005 18:38:59
I bought a new JD 4 position switch and since mine was rusted in the back severely I couldn't read the back. The new switch has different markings on the back so I puchased the 2029 manual for wiring diagrams. still have some questions. I need to replace some wire, what gauge do I need? And is the resistor on the back of my switch only for lights and does it matter which direction the juice flows through it?
John T
04-07-2005 19:10:16
 Re: 70 gas wiring problems in reply to bruddies pop, 04-07-2005 18:38:59
When rewiring usign an old fashion Generator, I generally use 12 Gauge in the charging circuit (from Voltage Regulators BAT terminal up to the ammeters load (NOT to battery)terminal) PLUS the main input power circuit (up from starter post to the ammeters supply (NOT to Voltage Regulator) terminal and maybe from the ammeters load terminal over to the switches BAT input terminal) but 14 Gauge elsewhere like in the lighting and ignition circuits.
This isnt standard, but Ive been known to even run 10 Gauge wire in the ignition circuit so the coil will get all the voltage reasonably possible lol On that switch, its the BAT input terminal thats fed power off the ammeters load side terminal and then it should have a terminal IGN that gets hot in the first position and stays hot (it feeds the ignition coil circuit regardles if lights on or off bright or dim) and then the other terminals are like for Lights and Back and Dim or something??? like that. My guess is if it has a light dimming resistor on board, its already fed hot when in the DIM position and then its output is what gets wired to a certain light.
Thats a very generic answer, no guarantee as its NOT from any diagram, and it never hurts to oversize the wire a tad and the use of 12 and 14 Gauge where I say wont hurt nothing.
John T
John T
04-07-2005 19:12:35
This isnt standard, but Ive been known to even run 10 Gauge wire in the ignition circuit so the coil will get all the voltage reasonably possible lol On that switch, its the BAT input terminal thats fed power off the ammeters load side terminal and then it should have a terminal IGN that gets hot in the first position and stays hot (it feeds the ignition coil circuit regardles if lights on or off bright or dim) and then the other terminals are like for Lights and Back or Bright and Dim or something??? like that. My guess is if it has a light dimming resistor on board, its already fed hot when in the DIM position and then its output is what gets wired to a certain light.
John T
bruddies pop
04-07-2005 19:19:56
 Re: 70 gas wiring problems in reply to John T, 04-07-2005 19:12:35
Thanks John, My daughter wants to know if the fixing ever ends on these beloved 2-bangers.
John T
04-07-2005 19:34:59
 Re: 70 gas wiring problems in reply to bruddies pop, 04-07-2005 19:19:56
She sounds just like my favorite daughter lol Its that female thing dont ya reckon
John T
