4520 w/Egging cab - what a/c unit?
Dwayne TX
02-20-2004 09:38:08
Just bought a 4520 with an Egging cab. The air conditioner was removed so there is just the round flange. The fan and control panel are gone, too. Only the vent and housing are left. What kind of unit did this have and/or what can it be replaced with? Thanks.
Roger
02-20-2004 10:04:54
 Re: 4520 w/Egging cab - what a/c unit? in reply to Dwayne TX, 02-20-2004 09:38:08
My Case 930 LP has a Egging cab, it has a cab cooler instead of an A/C unit. A/C units work better in high humidity climates where a cab cooler uses water evaporation to do the cooling, If I understand it right it is adding moisture to the air to help do the cooling,where an A/C unit removes excess moisture, don't make much sense but that's what it does, there is a garden hose up the back of the cab to fill it occasionally.
Dwayne TX
02-21-2004 06:48:03
 Re: Re: 4520 w/Egging cab - what a/c unit? in reply to Roger, 02-20-2004 10:04:54
Thanks, Roger. That's probably the reason it's not there, we've got plenty of humididity here!
