48 loader question
Bob
02-20-2004 09:13:41
I have a 1967 JD 1020 and am looking to install a frontend loader for cleaning horse stalls, etc. A well-meaning friend recommended a model #48 loader. I admit, I don't know what I need. Any help is much appreciated!
buickanddeere
02-21-2004 13:36:50
 Re: 48 loader question in reply to Bob, 02-20-2004 09:13:41
Mother Deere has new loaders that will backfit all the way to the 20 series. Sometimes new stuff off the Deere lot isn't much more expensive than pre-abused and usually fewer headaches.
stew
02-21-2004 08:02:08
we ran a 48 loader on our 1020 and had good luck with it till we went to a 2640 ,, a friend of mine has run a 48 on his 1020 for years, the only problem you might have is the front end (spindles etc) can give you grief if you are going to do alot of heavy work
SmallOps
02-21-2004 02:58:30
I have a 48 Quik-Tach Loader with the 74 inch bucket mounted on my JD 1020. I use it to clean the horse stalls, turnout areas, etc. and the combination works just fine.
The real advantage of the 48 loader is the other 90 percent of the tasks this loader performs around the farm. It has the lifting capacity, flexibility and ruggedness to be considered my most useful tractor implement!
Its true that the combination 1020 and 48 Loader looks a little awkward... but its stable and nimble when doing your chores. So, who cares if it looks like a big green Fiddler Crab?
David
02-20-2004 15:03:08
48, 145 and 146 loaders will fit, but I agree they are a little big for a 1020. I'd suggest a JD 47. They are harder to find, but are out there. Good luck.
Premier_Industries
02-20-2004 14:20:40
I have a 1020 with a 48 loader mounted on it. I should fit just fine although it does seem like a little bit of a overkill for the size of the tractor. But to answer your question yes it will fit.
I just got done looking at the owners manual and it says that this loader will fit 1020,1120,1520,2020 and 2030 with mounting brackets BC 10575. And 2120,2510,2520,3010,3020,4000,4010 and 4020 with mounting brackets BC 10467.
Pretty versatile loader.
Larry
02-20-2004 11:31:34
This is only my opinion, but I would think a 48 loader would be over kill on a little 1020 assuming you could get it mounted. I can't say as I have ever seen one on a smaller tractor like that and finding brackets might be a problem. I would think a 146 or similar would be better as they were designed for a utility type tractor.
Daryl
02-20-2004 12:49:25
 Re: Re: 48 loader question in reply to Larry, 02-20-2004 11:31:34
I have a 48 loader on my 2030 tractor which my father bought new. It is a row crop utility and has worked great. My 2030 has about 60 horsepower. I've had the bucket rebuilt four times, so you know it is handy.
