Gator Transmission
Steve Lietzke
04-07-2005 12:21:33
4x2's shift lever pops up and out of gear as soon as your rolling. Ok if you hold it down but annoying. What's causing this and how is it repaired.
Buckeye
04-08-2005 10:47:55
 Re: Gator Transmission in reply to Steve Lietzke, 04-07-2005 12:21:33
I had to rebuild my transmission because it was jumping out on my 6x4 Diesel gator. It finally got so bad that when you were in a hard pull you couldn't keep enough pressure on the gear shift to hold it in gear(actually broke the gear shift rod). My gator does have about 3500 hrs. on it though. I put 500-600 hours on it per year. Not a big deal to fix. Hope yours is just a linkage problem.
Doug in IL
04-07-2005 19:54:29
If I remember correctly, there is a long threaded rod that goes thru the lever on top of the transmission. A nut on that threaded rod had backed off. I think there are 2 nuts on the rod, to provide adjustment. I had this problem not long after I got the machine. I fixed it once, and it's been ok since.
