4230 jerky hydraulics
jerryd
04-07-2005 08:25:32
I have a 4230 w/148 loader on it that when I'm loading out alot of round bales once in a while the hydraulics get jerky then clears right up. I know based on former posts this is from using hydraulics when the clutch is in and the trans screen could be the cause...my question is where is this screen and is this something that can be cleaned or just replaced? thanks
donmyeil
04-08-2005 06:29:58
 Re: 4230 jerky hydraulics in reply to jerryd, 04-07-2005 08:25:32
After checking the filter try setting the engine up a couple hundred rpms to see if this helps. The transmission pump could be getting worn as well. The weight of the bale causes the cylinders to extend faster than oil flows so the system has to catch up. Had this problen on a jd301 with the small pump while loading limestone. I put on a 4.0 cu in pump and solved that problem.
Mike Becker
04-07-2005 20:36:58
I had a 4030 with a 148 loader and quad range years ago. Had the same problem until I put the 5 quart demand reservoir on top of the front pump behind the air screens by the fuel tank. Transmission pump is a high volumn low pressure pump, the front 8 cylinder radial pump is a high pressure low volumn pump. Back pump cannot keep up with the front pump demand, so you get chatter or pump cavitate. JD service tech says the tank kit is no longer available but you can get enough pieces to make up a reserve system anyway. Sure solved our problem.
Mike
WTW
04-07-2005 09:21:57
jerry, The clutch pedal position on a 30 series tractor should have nothing to do with the hydraulics operation of the loader in a normal operating system. That scenario applies to 10 and 20 non Powershift series only. The transmission pump on all 30 series and newer tractors are live no matter what your transmission option is. If the clutch pedal position does seem to affect the hydraulics, that would be a indication that you have a leak in either the clutch or two speed circuit of the tractor which could be the cause of your symptom. Again normally the clutch position should not effect the hydraulic operation of your 4230 tractor. Give me some more information And I will try to help some more. DW
jerryd
04-07-2005 09:47:54
 Re: 4230 jerky hydraulics in reply to WTW, 04-07-2005 09:21:57
Well i just got this at a sale a week ago with the loader on it. I got a new hydraulic filter yesterday but haven't got it in yet. While loading bales on a wagon, after setting the top bale on I back up and go to curl teh spear back up it chatters some for appx 2-3 seconds then returns to normal. I know the filter must be changed but I don't see why that would make a difference because normally the loader works with plenty of power and speed. Do you know anything about the trans pump screen and its location and whether I should buy a new one or clean mine? thnaks. It is a quad-range if it makes a difference.
WTW
04-07-2005 12:53:09
 Re: 4230 jerky hydraulics in reply to jerryd, 04-07-2005 09:47:54
jerry, I rather doubt that your screen or filter is restricted or plugged, because if it was your hydraulic functions would be slow and possibly chatter all the time. If this chattering is happening only after you roll the heavy bale off the tine I would suspect that the load (weight of bale) is causing your bucket cylinders to cavitate / (not refill) on the return side fast enough. Some loader valves have a regine circuit feature in them to keep this from happening but sorry to say this feature is more often found in commercial and industrial type of equipment like high hoes and backhoes. To prove this theory repeat the loader function with less or no load / bale on tine and see if it chatters if it don't it probably something you may have to live with. There may be loader valves on the market that have make up valves designed in them to keep this from happening. The boom on the loader takes the most oil and if it raises up and down without chattering the hydraulic system on the tractor is probably OK. DW
trower
04-07-2005 18:54:49
 Re: 4230 jerky hydraulics in reply to WTW, 04-07-2005 12:53:09
the screen on your 4230 is located behind and below your trans. filters. it is a round plug with a 1/2 inch square hole. it is probably really tight. you have to drain the fluid to clean this screen. in my experience a jerky loader in a 30 series tractor is a sign of a lack of oil to the main pump. a plugged filter, screen or bad trans. pump.
