Ever wonder why the lights
msb
04-07-2005 06:43:55
The reason Deere engineers went to lights instead of gauges was they recognized that a lot of tractors,especially in the South were operated by hired help and a lot of them didn't know 20PSI from 40 PSI or what the pressure should run,They did know when a red light came on to stop the tractor.That was the reasoning behind the lights that service engineers told dealer mechanics at service schools back then.
Gerald J.
04-07-2005 13:36:33
 Re: Ever wonder why the lights in reply to msb, 04-07-2005 06:43:55
Good answer for thinking types but the bean counters liked the lights because the light, light socket, wire, and pressure switch cost much less than a good pressure gauge with reliable plumbing. And cost less to install.
Gerald J.
WTW
04-07-2005 14:25:51
 Re: Ever wonder why the lights in reply to Gerald J., 04-07-2005 13:36:33
In all honestly I would not be surprised to find out that there is allot of truth to what you say. But on thing I will also say and bet my bottom dollar on, is that a working warning light saved allot more (John Deere) engines than any oil pressure gauge ever did. The reason I say this is because I know for a fact that a red light coming on all of a sudden got allot more attention than the attention the oil pressure gauge needle got when it went down. Operators do not watch there gauges constantly. Ask John Deere owners how many 30 series tractor engines got ruined when the cam / oil pump gear took the big one and the common comment from the operator when this miss fortune happened was: I didn't notice the oil pressure low, but I did notice the tach quit working! The best option in my book would be both the gauge and the warning light which most modern equipment have. But if I had to choose just one I would take the light. Twenty five years repairing John Deere equipment and engines made me a believer. DW
Gerald J.
04-07-2005 15:45:04
 Re: Ever wonder why the lights in reply to WTW, 04-07-2005 14:25:51
The switch would be even more effective if wired as a "Murphy" switch often used on unattended engines so if oil pressure disappeared the engine stopped. Probably would require electric stop on the diesel. And then an indicator of what happened. Like some recent Briggs engines.
Gerald J.
G/MAN
04-08-2005 07:46:04
 Re: Ever wonder why the lights in reply to Gerald J., 04-07-2005 15:45:04
We see quite a few New Gens set up with Murphy gauges around here. If the tractor is a key-start later model, it's simple to wire the "ignition" wire to the pump shutoff right through the 117 switch. If it's a tractor that's shutoff with the throttle lever, you must install an in-line shut-off in the fuel supply line. A lot of guys use them on booster pumps for irrigation. I've even installed Murphys on a 7700 of all things. Pretty high-dollar tractor for running a booster pump, IMHO. I also installed a tranny-pressure switchgage on that one.
