John Deere 450 Crawler
Basil
04-07-2005 06:35:58
I have a 1970 John Deere 450 Crawler dozer. It has the 4 cylinder diesel in it and I want to either rebuild or get a new one for it. Anyone know where I could possible get a new engine for it? Or a rebuild kit? I just redid the tracks a year ago and now its the engines turn. It runs but, it smokes horribly and has very little power left in her. Can not seem to find parts. Any help would be appreciated. Thanks
jdemaris
04-07-2005 20:12:47
 Re: John Deere 450 Crawler in reply to Basil, 04-07-2005 06:35:58
That is a very common engine and parts are easy to get in many places, including this website. You've got to determine what size engine you have, 450 engines got bigger as they got newer. Just look at the ID tag on the engine. Same engines were used in Ag. tractors like the 2510, 2020, etc. Main thing you have to watch for in your engine is the balancing shafts. Deere 3 and 6 cylinder engines don't have them, but your particular 4 cylinder engine does. That is because 4 cylinder engines have an innate balancing/harmonics problem. So, what often happens in 450s is - they get one or two "in-frame" motor jobs that don't include the balancing shafts. Then when the next motor job comes around, the shafts are so worn the engine won't hold any oil pressure once it's hot. Replacing the shafts and bushings is not part of a normal "in-frame" rebuild, and you'll have to pull the front timing cover to change them. Other than that, it's a very easy engine to work on.
Skyhawk Greg
04-07-2005 17:58:30
Basil, There are several people in the "crawler" section of this forum that could help. Try posting there. Greg
basil
04-07-2005 19:50:04
 Re: John Deere 450 Crawler in reply to Skyhawk Greg, 04-07-2005 17:58:30
Thanks I"m new here, did not see the "crawler" section.
