How To Remove JD-40 Radiator
Wayne Mo
04-06-2005 21:40:05
I am in process of restoring my JD-40 and spent a lot of time removing the radiator. I could not figure out the procedure but finally got it out my own way. I removed almost everything! What would a mechanic do to just remove the radiator after you remove the mounting bolts? I loosened the hoses but it would not come out. The hydraulic lines and the fan blade were the biggest problem. Should I have removed the fan blade first and also the hydraulic lines? Also the air cleaner maybe should be removed first. How do you guys attack removing the radiator?
Thane
04-07-2005 09:14:35
 Re: How To Remove JD-40 Radiator in reply to Wayne Mo, 04-06-2005 21:40:05
I did the same thing you did when I removed the radiator on my 40W. I couldn't believe all the things I had to take apart!
Mike M
04-07-2005 04:49:47
Sounds like you did it just right. Remove as you go as needed. These old tractors are hard to get the radiators out of compared to newer ones.I guess they figured you could fight it once every 50 years.
