Stained crank journals....720lp
Ben.So.Tex
04-06-2005 19:39:31
One of the journals on the 720lp has dark stain, does not look like rust. I will try some emery cloth on it tommorrow to see if that will remove it.. It does NOT look like it was caused by heat. What could be? Thanks Ben..
BushogPapa
04-06-2005 20:49:12
 Re: Stained crank journals....720lp in reply to Ben.So.Tex, 04-06-2005 19:39:31
It was probably "Etched" by acid in the oil...
Don't ever use emery on a crank journal..!!!
Use Crocus cloth torn in a strip the width of the journal..oil it and wrap it around the journal, and then wrap cotton clothesline around that--coil beside coil, and use the ends of the clothes line to Spin the crocus cloth... It Will do a wonderful job of polishing...
Ron..
