720lp/blockout/one piston still stuck....
Ben.So.Tex
04-06-2005 19:30:51
Got the block out of the 720 today, But one of the pistons is stuck. I beat it with a 2x4 and big hammer,try to press it out with a hydrlic jack, soaking it with brake fluid now. Need some ideas folks if you got any on how to make it give up,,Thanks Ben
JDBert
04-07-2005 06:33:29
 Re: 720lp/blockout/one piston still stuck.... in reply to Ben.So.Tex, 04-06-2005 19:30:51
I've never had one stuck enough where I had to take the block pistons and rods out, all the ones I've done (6 now) I got loose by just filling up the crank case with diesel fuel as well as the front side (through intake). But my neighbors 720 gas was stuck like this, we just beat them out after doing the hot pressure washer. If I ever have to do another one though I think I'm do it with the diesel gas mix and light it up. ONE WORD OR CAUTION WHEN YOU START TO BEAT THE PISTON/ROD OUT MAKE SURE TO HAVE SOMEBODY HOLDING IN ON THE OTHER END, other wise you run the risk of breakage if it hits the ground OR the rods slaps the piston skirt.
CLW
04-06-2005 21:20:00
Ben, Clooney has said you can stand the block up and pour about one inch of diesel mixed with just enough gas to light it. Let it burn out then repeat. When it burns out the second time use the block of wood and it should come out.
CLW
F-I-T
04-07-2005 09:09:01
 Re: 720lp/blockout/one piston still stuck.... in reply to CLW, 04-06-2005 21:20:00
third party image
That's how I do it if I have the block out of the tractor. Notice my Farmall Cub C-60 absorbing some BTU's.
The other way if you let the head on, is to fill with diesel fuel, then hook a garden hose from your water heater into the drain hole on the head and let the hot water go in the bottom and run out the top. Set it on a trickle so the heater can keep up when set on high. 10-15 minutes later the block and head are warm and the piston has had a chance to get lubrication, and a gentle rocking of the flywheel gets things loose with no damage. This works well if it has stuck over the winter from sitting.
Frank
Roy Suomi
04-06-2005 20:00:50
I just ran into a 40 with stuck pistons. I soaked the heck out of it with a product called Kroil. I've used this penetrant for years. In my book, it's the best stuff out there. I soaked it , gave it a couple of raps with a hardwood block and a good sized hammer. Did this for a couple of nights. It broke loose. I then took a cylinder hone to the rust above the piston so the rings didn't have to scrape the rust off the cylinder walls
Gord
04-06-2005 19:57:45
I had success with a very stuck piston in a Model A block. I used our hot water pressure washer set to its highest heat-about 180 degrees F. I put the wand into the water jacket and left it running until the block was hot to touch. Then I put the block in the press and pressed the piston out. It wouldn't move until the block was heated up and actually came out fairly easy and without any damage. Might be worth a try.
