swaping front ends on a 420
aklerk
04-06-2005 13:42:26
Got a 420 T narrow front end. Can a wide front end be put on this tractor?
T Sherman
04-06-2005 14:39:47
 Re: swaping front ends on a 420 in reply to aklerk, 04-06-2005 13:42:26
If the front end is from a wide 420T there will be no problem. If you are trying to switch from a 420W or S it will be very difficult. The rear axles are different along with the whole front end pieces from the motor forward. Nothing is impossible but it would be very impractical and expensive.
Wayne in Tn.
04-06-2005 16:22:24
 Re: swaping front ends on a 420 in reply to T Sherman, 04-06-2005 14:39:47
As Sherman said, the wide front will have to come from a "T" donor tractor, ie. 40T, 420T, 430T Then it is a very simple changeover. But a front end from a W,S,U, ect. will have to have every thing changed from the motor forward, and then you will have the wrong final drives to match the front end.
