BGuy and the pic of the Remote on the 420
Henry J
04-06-2005 11:27:26
Thanks for the picture. I have it in my binder since it will be a while before I get around to finishing that project. If you got the time I have a couple more questions, since my 420 manual says (for illustration purposes all pictures of the remote will be one mounted on a 40T)-sigh.
One. Does the bracket that the brake lever goes through have one or two holes in the top of it where the lever goes through?
Also, I noticed the hydraulic hose hooked into where the (i think 3/4) plug is on the lower front side. Is this a return possibly for pioneer fittings that have been added in the rear?
Thanks again
Bguy
04-07-2005 18:04:39
 Re: BGuy and the pic of the Remote on the 420 in reply to Henry J, 04-06-2005 11:27:26
third party image
Henry J, I checked my 1958 420W out again this evening and the bracket on the left is just like the one on the right. They both have two holes which is so they can be used on either side I suppose. The one on the left has a spacer under it so that it sits out off of the cast brake drum housing about 1/2 inch. As we discussed earlier, the rod bends out to accomodate this. My 1960 435 has a different type of bracket. It is like the attached pic R. Bagwell refered to in the other post. I have had the serial numbers researched thru 2-Cylinder Mag and they both came from the factory with remotes. Of course, the 420 may had been altered somewhere along the way or maybe only the later ones had the special bracket, I don't know. As for the hydraulic hose, it is the TOM bypass line to the front cover. The parts book shows a short metal line running out of the front cover to the near side of the valve body which the 435 has but my 420 has a plug there and the hose goes around to the far side. So, again, I don't know the story on this but it does appear to be factory, works good and doesn't leak so I'll let it be.
Bguy
04-07-2005 18:06:20
 Re: BGuy and the pic of the Remote on the 420 in reply to Bguy, 04-07-2005 18:04:39
Wow! Is that picture big enough for you? Sorry about that!
Dave - Ia
04-06-2005 18:41:14
Am I right in guessing that the bracket that holds the top of the rod is just out farther from the brake drum so that their would be more room to get your hand to it? I have been looking at mine and it looks like that might be the only difference.
Henry J
04-07-2005 08:44:18
 Re: BGuy and the pic of the Remote on the 420 in reply to Dave - Ia, 04-06-2005 18:41:14
Dave
I did some measuring on those two brackets this am. First I think the big difference was an engineering thing. The bracket without the remote sat neatly in the two casting protrusions on the brake cover. When the remote mounting bracket was added this precluded the regular bracket from having something to brace into to prevent any tendency to rotate since it has one mounting bolt hole.
So they redesigned a bracket that is stamped out of lighter metal. The bracket (one with remote valve) has a tab about 1 1/4 inch long that bends to the inside so it fits under the remote mounting bracket to prevent and rotational tendency. Then farther to the rear it has a tab bent out to the outside of the tractor that has the hole for the brake set lever.
The end result is that the part of the bracket that the rod goes through has a hole center that is exactly the same distance outboard from the tractor and the center of the hole is exactly 1/2 inch farther to the rear of the tractor.
If you would like, I could sketch up a drawing for you if you are inclined to make this type of thing. I really don't think it would take long to knock one of these out with the big ball peen and a vice since the thickness of the metal is considerably less that the other type bracket. [email protected]
Dave - Ia
04-07-2005 19:08:57
 Re: BGuy and the pic of the Remote on the 420 in reply to Henry J, 04-07-2005 08:44:18
Thanks Henry for taking the time to check out the difference between thes brackets. From the way you describe it and the picture above it should not be a problem getting this mounted. I purchased a couple of rods and brackets last summer, so parts are on hand. Thanks again.
Bguy
04-06-2005 13:28:24
No Problem. Let me check on it tonight to refresh my memory and I'll post back tomorrow.
